Whenever I turn my computer on, the bottom quarter of my monitor looks like it is broken. Lines across the bottom and whatnot. However, it goes away after a minute or two. It went away as I typed this, so l couldn't get a picture. I'll edit this post later to show a pic.
The weird thing is that I just was messing with it, and if I change my project settings to duplicate, the lines go away, and it looks normal. Then, I go back to extend or primary monitor, and the lines return.
So, what I thought was a problem with my monitor may be more software-related. Has anyone ever heard of this? I also tried changing the output to 1080, which is what my second monitor runs at, and that didn't help
edit: I attached a video of the screen doing its thing and then me switching to a different project setting and it magically going away
https://linustechtips.com/topic/1548334-weird-bug-going-on/
Try replacing the display cable for it and see if that may be your issue. Bad cables can sometimes cause glitching like this, and is usually the first thing you can try to diagnose your problem.
it is what it is
Main PC
AMD Ryzen 7 7800X3D | Gigabyte B650 Gaming X AX | 32GB 2x16 DDR5-6000MHz | RX 6800 FE | 2x 1TB SSDs | Windows 10 Enterprise LTSC 2021
NAS
Intel Core i3-7100 | ASUS Z270M Prime Plus | 16GB 2x8 DDR4 | 256GB Samsung SSD | 4x2TB WD Blue HDDs | TrueNAS Scale
Windows XP Gaming Rig
Intel Xeon E5-2620 | 32GB 8x4 DDR3-1600MHz | ASUS P9X79 LE | GTX 960 | 500GB HDD | Windows XP Professional
https://linustechtips.com/topic/1548334-weird-bug-going-on/#findComment-16254268
