US DOLLARS
Right now I have ryzen 5 7600, Asus 1660 super, 6000mhz DDR5 ram.
I whould like to know what GPU upgrade I should get? Either 4060TI or 4070? or other tips (NVIDIA)
I play games like, Fortnite, CSGO, Valorant (mostly CPU based games)
Where im from (SWEDEN) The 4060 ti goes for around 608 dollars to 700 dollars.
EXAMPLES
List from cheapest to expensive
GIGABYTE GeForce RTX 4060 Ti 16GB - 608 Dollars
MSI GeForce RTX 4060 Ti - 16GB - 625 Dollars
ASUS GeForce RTX 4060 Ti ProArt OC - 700 Dollars
4070 is around 765 dollars to 840 dollars
EXAMPLES
GIGABYTE GeForce RTX 4070 EAGLE OC V2 - 12GB GDDR6X RAM - 768 Dollars
Palit GeForce RTX 4070 JetStream - 12GB GDDR6X RAM - 782 Dollars
Palit GeForce RTX 4070 GamingPro - 12GB GDDR6X RAM - 839 Dollars
If you want to see other prices check websites like Amazon.SE, Proshop.Se Inet.Se or Webhallen.com for my prices. I whould like the price not to exceed 820 Dollars.
Thank you for reading this 🙂
Video regarding amd vs nvidia on example fortnite -  https://vm.tiktok.com/ZGeNFDTMF/
If you search on reddit/google about amd radeon and then fortnite dx11/dx11 performance mode you will se many people complaining about the fps drops, this is main reason i whould want to choose nvidia since fortnite is my main game.
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/
What resolution and hz are your monitor running? If it's an old 1080p 60hz you can pick the cheaper one.
But maybe you could wait for a sale after christmas? Mellandagsrean?
I usually edit my posts.
Refresh the page before answering to my post.
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248874
16 minutes ago, DeathPointforYA said:
Absolutely not, are you serious? 600 for 4060 ti?? That is even more overpriced than on the other places, Ngreedia sells nothing of worth period. You can probably find RX 6800 XT or 7800 XT for the same price with massive performance increase.
ik that AMD is way better price to performance but many say that for the games i play NVIDIA performes better example of this is in Fortnite, Fortnite DX11 performance mode is NVIDIA better but at DX12 Amd is better, AMD performes worse in DX11 many says and also gams are more optimized for NVIDIA i belive
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248902
22 minutes ago, Guggenheim. said:
get a 30 series nvidia or an amd gpu, 4060 ti for 600 bucks is daylight robbery
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248908
You are completely mislead, the fact that AMD offers way better perfomance for the price more than enough counters a little worse optimalization. 6800 XT is about 30% faster and 7800 XT is 35% now that is for the same price. The fact is that you do not need to spend that much to get about the same results. You had said it yourself, the games you play are mostly CPU bound. I think for your purposes you would be completely fine with 6700 XT level of performance. 4060 Ti is usually sold around 400/450 and that is a bad price already. There is absolutely no justification for 600 price tag.
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248923
What brand for Radeon should i get? sapphire, asus, asrock etc, NVIDIA also has dlss, raytracing etc so i dont know if i should choose nvidia or amd
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248934
Pc parts in Sweden are expensive nowadays.
I bought my 4060 8gb for 4290 sek, which is about 420 US dollar at the moment.
The 30xx series have also been phased out from stores already, otherwise I would've bought a 3060 12gb for a much lower price than the 4060.
I remember when I bought my 1060 3gb for less than 2000 sek. It was before the 20xx and the 16xx series had arrived so it was quite new back then....
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248936
https://www.amazon.se/dp/B09YJ222L6?th=1&psc=1
Found this for the price of 6700 XT lol, enjoy
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248941
remember paying like 260 for my 1660 super a few years back
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16248947
Who says?
Game developers optimize for consoles which have AMD gpu's.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16249532
On 12/17/2023 at 4:20 PM, Awkward1337 said:
AMD is badly optimized fro DX11 on fortnite as example,
are you really gonna play fortnite on dx11 on a card which can run it 200 fps+ on dx12 though? you even said it yourself that the amd cards perform better on dx12.
Quote
i think they should all be fine but ive heard the amd exclusives are of much higher quality (xfx, powercolor, sapphire).
Quote
amd also has fsr2.1 and its just about as good as dlss, raytracing performance on the other hand is super crap on amd side (at least compared to nvidia in some demanding games like cyberpunk). at this moment in time, RT is just a fad, i tried it on my friends computer and i was extremely underwhelmed. a 6800xt or 6700xt should have the same performance of the 4060 with rt though cause that card isn't particularly fast. the 40 series also has frame generation which is suuuuper cool, but all in all i would side with AMD cause at 600$s you can get much better raw performance on team red
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16251109
I prefer to play on Dx11 because of visual advantages
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16252172
Bear in mind that European prices always include sales tax. I can't remember the Swedish tax rate but in Denmark it's 25% and we do have similar systems
mITX is awesome! I regret nothing (apart from when picking parts or have to do maintainance *cough*cough*)
https://linustechtips.com/topic/1547519-help-me-upgrade-gpu/#findComment-16256805
