High temperature cpu I need help
Hello everyone, I have a problem, my motherboard has a CPU sensor, when I open a game the sensor has a reading of 64º but the Ryzen CPU sensor is above 80º, and the CPU fan only recognizes the motherboard sensor and it does not increase the speed, it has reached 95º but the sensor that is built into the motherboard continues to read the temperatures incorrectly, I am currently using a program called Fan Control to link the CPU fan with the sensor of the Ryzen but I would like the board to do it automatically, as it should do. Please I need help
Motherboard: B550 Phantom Gaming 4
CPU: Ryzen 5 5600X
16GB DDR4 3200mhz
Image showing the CPU sensor from the motherboard on HWinfo beside Ryzen Master
Image showing the CPU DIE from the Ryzen on HWinfo beside Ryzen Master
https://linustechtips.com/topic/1546675-high-temperature-cpu-i-need-help/
Is using fancontrol to decide the sensor the fan runs off, the fan curve and therefore fan speed an issue?
Also HWinfo can sometimes have an issue where if another programme is running and displaying sensors, HWinfo will be slow to update, therefore CPU temp readings could be right, but not updating quick enough to catch a quick jump in temps?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
3 hours ago, Needfuldoer said:
What cooler are you using?
Is the CPU cooler fan plugged into the CPU fan header?
Did you remember to peel the plastic off the heatsink when you installed it? 😉
I am using the stock fan, yes, i plug it into the CPU_FAN1 and when i mount it, i put some thermal paste on it, that my friend gave me, an artic mx-5.
No, I am using a software called FanControl to be able to manage the cpu fan speeds at the moment, because if I close it, the processor reaches 92º and the fan does not accelerate the rpm.
Turn on the minimise on close option in fan control, then it'll stay active even when closed and the app is idling
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
What is the temperature source that is chosen in the BIOS to automatically control the CPU_FAN 1 header?
On 12/13/2023 at 6:16 PM, Zencon said:
L3 Cache
What other options do you have?
