Power limits Intel Apollo lake
6 hours ago, josefah said:1-2%
You are under estimating the possible performance increase. A N4200 running at its base frequency is only 1.1 GHz. Increasing the turbo power limits might let a N4200 run as fast as 2.5 GHz. A 125% increase in CPU speed is something worth trying to unlock. Increasing the package power can also help the Intel GPU maintain full speed longer or indefinitely.
6 hours ago, josefah said:It's kind of needlessly dangerous.
How so? His CPU is only running at 62°C. The N4200 starts to thermal throttle at 105°C. There is plenty of head room available to raise the power limits. Increasing the turbo power limits way beyond the 6W TDP rating is not going to hurt anything. Some users are increasing the turbo power limits to 15W. This can double the iGPU performance.
Yes it will still be an old slow processor compared to the latest technology from Intel but increasing the power limits might mean the difference between a useable device and an unuseable device. Not everyone can afford to buy the latest hardware.
Lots of good info in this forum thread about removing the secondary turbo power limits.
