6 minutes ago, marymates said:
Is 750W psu enough for GeForce RTX 2070 and I5-12600K enough? I am not much into computers so idk if its mid, high or low.
Other specs:
32gbs of ram (ddr4)
SSD 1TB
Yes, more than enough 🙂  Its even a bit high but going a bit higher on the PSU leaves room for upgrades later 🙂 you could technically power that on a solid 550-600w.
12600k max wattage is 150w with the 2070 peaking at 175w,  Thats 325w if both GPU and CPU are running at 100%, DDR4 ram uses around 4-6w per 8GB and an SSD uses around 10w when writing, fans use around 2-4w.
So lets say 400w during full load.
https://linustechtips.com/topic/1545020-help-with-psu/#findComment-16231847
