macro keypad with repeatable macro
hi,
i am looking for some cheap keyboard/pad or an extention that can provide a few macro keys.
there are tons of cheapo keypads out there but those do not seem to be able to provide repeatable strokes,
as that functionality may require some additional cpu/power.
my mechanical corsair k68 unfortunately does not have macro keys and spending +$200 on another mech keyboard is not an option.
my G900 mouse does provide this but it needs to be wired for this.
any  suggestions?
https://linustechtips.com/topic/1544982-macro-keypad-with-repeatable-macro/
1 hour ago, nug said:
hi,
any  suggestions?
Some reddragon's keyboard is mechanical, have macro keys, and under $100
Example : https://www.amazon.com/Redragon-Mechanical-Bluetooth-Ultra-Thin-Connection/dp/B098785CL3
Refresh before you reply
https://epomaker.com/products/cidoo-v21
It supports VIA, so I would think it should support a lot of macros etc. 60$ isn't cheap, but I got one for a family member and they love it. Quality is nice enough stock, sounds and feels amazing.
Pretty sure you can find other numpads with VIA support, so maybe first figure out whether VIA can actually solve your problem, now that I think of it.
