I thought there was a way to remove the AM5 backplate, but it may void the warranty for the motherboard.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
https://linustechtips.com/topic/1544182-am5-cooler/#findComment-16226538
well there is just remove the screws from the front plastic parts and the rear comes away and that shouldn't impact on warranty as pretty standard to a cooler that does not use the generic amd fitting..but that does not solve the issue of the mounting bracket the cooler comes with for AMD
https://linustechtips.com/topic/1544182-am5-cooler/#findComment-16226550
Well the AM5 backplate is actually secured by the AMD mounting solution, and the socket itself, so you can remove the AM5 brackets and keep the backplate on, since it's secured via the socket itself. but I don't recall that cpu cooler coming with the right fittings that are correctly spaced to be able to not use the AMD brackets
https://linustechtips.com/topic/1544182-am5-cooler/#findComment-16228037
