System specs listed in the IObit Sysinfo Report.html file . (note I don't use any other IObit program except there program uninstaller)
Motherboard page  https://www.gigabyte.com/Motherboard/B550-UD-AC-rev-10-11#kf
Bios Drivers https://www.cyberpowerinc.com/drivers/?dir=Motherboards/BIOS/Gigabyte Im using this bios version MB-478-120 B550UDACY1 F4b.zip.
using older bios because newer bios makes high power usb devices randomly restart. I found it's a common issue on b550 motherboards
Windows has stopped this device because it has reported problems. (Code 43)
A request for the USB device descriptor failed.
Hardware ids: USB\DEVICE_DESCRIPTOR_FAILURE
Compatible ids: USB\DEVICE_DESCRIPTOR_FAILURE
Problem code: 0000002B
Inf Section: BADDEVICE.Dev.NT
Device manager events on the Unknown usb Device errors file (file from event viewer)
Check mkv screen record for issues with drivers on the usb.inf file.
IObit SysInfo Report.html Unknown usb Device errors.evtx 2023-11-26 18-15-38 - Trim.mkv
https://linustechtips.com/topic/1543656-unknown-driver-help/
