Aio cpu fan error...
Go to solution Solved by Kilrah,
According to the manual it's supposed to connect to the fan header.
Okay first build in 20 years, and she posted first time, but it will not boot.  I bought an Artic Liquid Freezer II AIO and have it plugged into the MB at the pump controller.  Maybe this is wrong?  Cause the BIO's says no CPU fan, and the computer will not boot.  I am on an X570 mb, Ryzen 7 5700x CPU,  any advice, do I need to move the AIO connection to a fan header? Or is there something I can do in BIO's to correct this... the cooler come pre wired to run the pump and fans together... so any advise?
https://linustechtips.com/topic/1543111-aio-cpu-fan-error/
F@H
GPD Win 2
https://linustechtips.com/topic/1543111-aio-cpu-fan-error/#findComment-16220299
