Budget (including currency): 110(usd)
Country: America
Games, programs or workloads that it will be used for: doesnt matter
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): basically I need an itx case that is under 110, is easy for a beginner, and has good reviews
https://linustechtips.com/topic/1542339-itx-case/
It's an aging design, but I like the Cooler Master Elite 130.
https://www.coolermaster.com/catalog/cases/mini-itx/elite130/
I only put an RTX 3060ti Founder's Edition in mine though, so I can't say how well it can accommodate a gargantuan flagship class GPU. But I chose it for my HTPC / semi-portable gaming PC because it has a 5.25" bay (for a Blu-Ray drive) and I think I can finagle a couple 3.5" hard drives in there as well.
I have a Thermaltake Core V1 coming for a different project. It's a shorter case though, so if you need it to hold a long GPU that's probably out of the running. (I don't need a GPU in this one.)
https://linustechtips.com/topic/1542339-itx-case/#findComment-16215706
