heard a loud pop from my Corsair HX1200 Power Supplies
Stuchy
at first the power supply did not turn on when I tried to jump it again. then I waited 5 minutes and was able to get it jumped and turned on what damage may have I done what should I be looking for as well is it possible to repair.  but seeing that it came back on it safe to use in my build or should I replace it straight away .
Nobody can know the answer to this unfortunately , There's a miriad of things it could have been.
CPU : Ryzen 7 7800X3D @ -18mv all core except -13mv on Core 5 because its a pig.
CPU Cooler : Deepcool AK620 Zero Dark
Mobo : MSI B650M-A Wifi MATX
Ram : 32GB (2X16GB) Corsair Vengeance DDR5 6000MHZ CL34
GPU : Reference Design RX7900XT sold by Saphire running at 1050MV undervolt and +15% PL (355w)
Storage : 1TB WD SN770 + 2TB Samsung 970 Evo
PSU : Corsair HX750w Platinum
Case : Asus Prime AP201 All Mesh MATX
Case Fans : Arctic p12's everywhere i can fit them in , 7 In total.
Monitor : LG 27GP850-B.BEK 1440p Nano IPS 180Hz
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
Layman's perspective: There are no parts that are supposed to go POP, so maybe get a professional to look at it, or RMA the parts if you can pinpoint what it was.
mITX is awesome! I regret nothing (apart from when picking parts or have to do maintainance *cough*cough*)
Hey man, you should just replace it straight away.. No PSU should have this POP sounds..
