Not all
Some cooler come with pre-applied, this is usually for stock cooler such as Intel or AMD or a budget 3rd party cooler
But for higher end 3rd party air cooler such as Thermalright PA, DeepCool Assassin or Noctua NHD-15 has thermal paste tube in the box and you need to apply it manually
Example of NH-D15 box content, it has NT-H1 thermal paste tube for us to manually apply on the CPU
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1541625-cooler-question/#findComment-16211390
8 hours ago, Byamps said:
Do air coolers come with thermal paste pre-applied or do I need to buy my own thermal paste?
Many come with it. On some it's pre-applied, but others you have to do it. If you see that the TIM is coming out really runny and seems to be separating, tell the vendor and get the TIM replaced.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1541625-cooler-question/#findComment-16211841
