So I have a somewhat unusual monitor setup for my PC that allows my mouse to cross over only a small section of my 4k monitor. My question is, is there anyway to set it up for my mouse to be able to cross across the area I drew out with the blue marks without connecting them in the display settings? Ideally I want to keep monitor 3 centered above monitor 1 but still be able to send my mouse cursor from monitor 3 to monitor 2 and vice versa. Is there a way to do this so I don't need to use monitor 1 as the middleman?
https://linustechtips.com/topic/1541432-dumb-multi-display-mouse-question/
LittleBigMouse might be able to help? Or maybe DisplayFusion Pro? Usually if they're not touching at all there isn't much you can do.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
