So yesterday I was using my pc (just built and finished) and it lagged and by instinct from using test bench's i shut it off from the psu switch and when that happend i would get a post but it would flash purple and i decided to reseat my GPU and when i did that i got no post at all. i could really use some help.
https://linustechtips.com/topic/1540536-no-post-on-pc/
Make sure all cables are fully plugged in on the motherboard end and PSU end. Reseat Ram. Does RGB light up or anything?
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
https://linustechtips.com/topic/1540536-no-post-on-pc/#findComment-16203526
3 minutes ago, DuckzWasTaken said:
Yes RGB Lights up i just get no moniter output
Then try another HDMI/DP cable, if your using HDMI use DP. What are your system specs? Try using a different HDMI or DP port on both the GPU and monitor.
My First PC
CPU: Ryzen 5 5600x
https://linustechtips.com/topic/1540536-no-post-on-pc/#findComment-16203542
Tried that And just reseated my ram and nothing
if you could drop your discord so i can talk in more detail
https://linustechtips.com/topic/1540536-no-post-on-pc/#findComment-16203551
Why can't you talk in detail here? My discord is in my bio.
My First PC
CPU: Ryzen 5 5600x
https://linustechtips.com/topic/1540536-no-post-on-pc/#findComment-16204683
