need help with rgb on rgb lit 100 case
ReSoFL
for some reason the back fan rgb the front panel and side panel rgb strip just cant be changed the reset switch does nothing when pressed and rgb fusion doesnt work for the case only for the graphics card
my motherboard is a gigabyte B550M DS3H
sometime i can change the rgb colours but i have to hold the power button off and on like 50 times just to cycle to the 2 colour modes it has its supposed to have 14
and the rgb lights in the case and back fan only stay in static mode
please help ive asked on reddit discord and even reached out to sharkoon support but they gave me no response
i even checked the cables to make sure nothings wrong and every thing was where it should be
That motherboard doesn't have addressable RGB headers, so to control the RGB you will need an RGB controller.
Something like this:
https://www.razer.com/ap-en/gaming-pc-accessories/razer-chroma-addressable-rgb-controller
or
https://www.coolermaster.com/catalog/coolers/rgb-accessories/led-controller-a1/
Failure is part of success. I may make mistakes, that's how we all learn.
Folding at Home
or
im pretty sure it has adreasble rgb headers ive tried everything still cant find the fucking issue
may need to get a new case
yea i know pretty dumb to change ur whole pc case just for rgb but im all aesthetics
Which version is your mobo?
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
B550M DS3H gigabyte
7 minutes ago, ReSoFL said:
B550M DS3H gigabyte
The version, not the model. According to Gigabyte, all versions except 1.5 have RGB and ARGB support.
bruh system info just says x.x
Well there are 7 versions, so you have a 1 in 7 chance of not having RGB & ARGB headers. 😉
So, on the v1.7 it shows that they are on the bottom near the left side.  RGB Fusion 2.0
