Cracked Side Panel (PC Case)
Solved by adm0n,
If you want it to be transparent, you could coat it with a thin film of epoxy resin on both sides. But you would need a dust free space to do this, and also some kind of guide at both sides. That would look the cleanest in my opinion.
Otherwise you could probably get away with gluing a window safety film on at least one side of your side panel. At least if you are capable of doing that without destroying it.
