Help with Psu and gpu
Solved by brob,
17 minutes ago, OHHwell said:so a 750w with 3x8 pin layout or should i go even higher
Depends on available budget. Often one finds the price differential between the 750W and 850W model is less than €10. In that case for sure go with the 850W model. But I wouldn't get a less well considered 850W over a higher quality 750W.
Consult https://cultists.network/140/psu-tier-list/ for rankings. This list is a bit dated when it comes to ATX 3.0 qualified PSU. If budget allows, consider an ATX 3.0 model as they are better able to handle transients.
