this is my laptop, it have i5 1035G1 and can run up to 3.6 ghz but idk how to enable that i tried everything just to see it run on its full core speed , unlike my old laptop which can run upto 2.6 ghz  which have base core clock speed of just 1.1 , this laptop also have that 1.1ghz base speed but idk how to boost it up 3.6
https://linustechtips.com/topic/1539150-turbo-boost-issue/
There is no load on the CPU... why would it be boosting?
https://linustechtips.com/topic/1539150-turbo-boost-issue/#findComment-16193226
1 minute ago, Shailesh Vats said:
herer is my second laptop after boosting all the core,can you see that 2.6ghz boost speed its not under load but works 100% all the time
There is absolutely no need for your laptop to be boosting without a load... it wastes energy, shortens battery life and produces heat.
I am yet to see your 1st laptop with a load on it, does it boost then? If it does, then there is nothing to fix.
https://linustechtips.com/topic/1539150-turbo-boost-issue/#findComment-16193231
both  the laptops usually lags in most of the general but boosting the cores helped me fix that issue in 2nd laptop, most of the time i use my laptop plugged, and these processor dont heat that much eve in full load , what is the fastest way load up my second laptop so i can take ss of it and post it here just in case it doesnt gets to 3.6 which is what i want
https://linustechtips.com/topic/1539150-turbo-boost-issue/#findComment-16193232
