Hello guys i have stuttring issues but all work fine i think is something with my power outlet!my keyboard leds and motherboard rgb still on after shutting down!How i check it?
When i turn on my pc on my graphics card rx6600 the fun speed for 5sec and turn off and vga on motherboard red light turn on!
https://linustechtips.com/topic/1537869-stuttering-issues/
8 minutes ago, Schnoz said:
What do you mean by stuttering issues? Frametime consistency? In that case, it's probs a Windows issue. DM me and I can provide a legitimate Windows ISO.
Your keyboard and motherboard RGB LEDs will stay on after shut-down because the PSU always supplies 3.3V and 5V power. You can configure motherboard LEDs to turn off in the BIOS.
Your GPU's fan going at full speed momentarily is also normal. This is the GPU testing that the fan is okay.
Can you send me a massage to explain beacuse im new
https://linustechtips.com/topic/1537869-stuttering-issues/#findComment-16183492
Just now, Schnoz said:
If you're getting a relatively high FPS but it still feels "choppy", that's an issue with inconsistent frametimes. Common issues are memory running in single-channel and Windows 11. Making sure your memory is dual-channel (at least two DIMMs, in every other slot) and installing Windows 10 often helps.
The reason motherboards continue to supply 3.3v and 5v power even when the computer is shut down is because the computer needs voltage to know if the power button is pressed, and thus when to turn on.
The reason the GPU fan spins up to 100% briefly is for the GPU to check that the fan is able to spin freely. It tells the fan to spin up to 100%, then monitors the expected fan speed to check that it's okay.
Thanku for helping me but i have a corsair dual channel 3000mhz of 8gb
https://linustechtips.com/topic/1537869-stuttering-issues/#findComment-16183506
2 minutes ago, Schnoz said:
I see! Try rebooting the computer, going into the BIOS, and checking that XMP is enabled (or set to Profile 1). What are the full specs of your system? What OS are you running?
I run windows 10
yes is on the xmp profile
I have a ryzen 3400g rx6600 2x8gb ram
750 hydra psu(new)motherboard aurus m b450
https://linustechtips.com/topic/1537869-stuttering-issues/#findComment-16183514
I see. Try re-seating the memory (taking it out and putting it back in). Also, try updating your GPU drivers.
Bro i rebuild the pc but not work I reinstall windows the sam thing i have stutter offline/online i dont wht latest driver!can the power outlet cause probelm?beacuse i have 5 devices on one outlet!?
https://linustechtips.com/topic/1537869-stuttering-issues/#findComment-16183526
