Advice for gpu upgrade on current setup
Solved by 191x7,
1 minute ago, thebeast7286 said:gotcha. Would you have solid cpu recommendation to go with the 4070 ti?
Just now, thebeast7286 said:I mainly play 1440. havent had much of an issue with the games ive been playing.
With 1440p it's easier on the CPU; so I'd say a 5700X would work and a 5800X3D would be ideal, and paired with a Radeon 6800XT, 7800XT, or an RTX 4070 Super (supposedly arrives soon).
