I keep getting repeatedly disconnected from CS2 with a pop up that says "remote host has closed connection." I have followed all of the official documentation on how to solve this issue with no fix. Fortunately I can immediately rejoin the game. I have the network issues popup enabled in game and most of the time I have no packet loss. However, often times I will get from 4 to 100% packet loss and then disconnect. This is why I think I have an internet problem.
My computer specs are listed in my signature, it is my main PC. All drivers, windows updates, game updates, and bios are up to date.
I use spectrum internet and I pay for gigabit down.
I use Spectrums Modem to TP-Link Deco WiFi 6 Mesh System(Deco X20), to TP-Link TL-SG105, 5 Port Gigabit Unmanaged Ethernet Switch, to my PC with Cat 6 ethernet cable.
My I have 3 routers. The two that aren't wired into my network are just used as range extenders. My PC is plugged in to the router that is connected by wire to modem through switch as previously mentioned.
Router: https://a.co/d/7kQ9CmL
Switch: https://a.co/d/cfIowpr
I do not understand ANYTHING about networking, but I have downloaded my .csv results of the cloudfare speedtest results to attach here along with a screenshot of my speedtest.net results. Please offer advice.
network speed cloudfare.csv
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1537670-cs2-repeated-dc-network-issue/
I have something similar happening, I see this issue with maybe 20 other people around the same time across the internet, I have verified it is not my internet and I thought maybe it’s because I’m on a college internet collection, but I have a friend in the same dorm hall that can play the game fine. Also have tried about everything and can find no solution
