59 minutes ago, TimedPing said:
What you gonna utilize this NAS for? just basic storage NAS? or running other service like Jellyfin, emby, Plex, etc? how much is your budget? and can you define "small sized system", is it very tight space or standard ATX size case is OK? Any redundancy config into the mix? any future upgrade options for it?
Running off the shelf prebuilt equipped system with Intel 7th gen core i3 is more than enough for most people, especially those Intel HD GPU already supported 10Bit high res video transcoding for Jellyfin/Plex/Emby stream on the fly, without resorting to buying GPU and save power.
I want to use this for mainly basic storage and maybe streaming video files in the future
And for the size, something small enough to put under a desk or a closet
https://linustechtips.com/topic/1537342-building-a-nas/#findComment-16179324
