First PC Build Advice
Solved by SorryBella,
1 hour ago, Mcrawford said:Thank you! I'll definitely ditch the speaker in that case. Question - The change in motherboard means it doesn't have in built wifi and bluetooth, right? Is buying separate adapters a better idea than the previous motherboard I had? I have no way to wire internet in my room atm, so wifi is a must, and I'd still like to be able to connect to my bluetooth headphones.
For bluetooth built in is frankly the only way but not every WIFI board comes with bluetooth. In that case the best pick would be either the B550-M Pro VC WIFI by MSI or TUF B550 Plus II by Asus.
