I recently updated my phone to Android 12 and the new gestures now have the "back" action activated by a swipe from the side of the screen instead of from the side of the bottom of the screen like it used to be.
It used to be swipe up from the middle of the bottom is home and swipe up from either edge of the bottom is back.
Is there any way for me to go back to this layout. I cannot stand swiping form the side of my screen.
Thanks!
https://linustechtips.com/topic/1532591-help-changing-gestures-on-android-12/
I've never heard of swiping from certain places determining what the action is of the phone, back or home. I've only known either side being back and a swipe from the bottom middle being home, couldn't go back.
Check if that isn't a manufacter specific setting or maybe if you're using a launcher, updaing to a new version broke the old launcher version.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
Thanks!
What phone model do you have?
(i.e., Samsung Galaxy S21+ or Google Pixel 6a)
