Advice for my computer
Go to solution Solved by Dedayog,
2 minutes ago, Epicernie77 said:
Thank you
This is a better machine for equivalent pricing...  better CPU, better CPU Cooler, double the SSD, PSU to support an upgrade...
PCPartPicker Part List
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  (£122.90 @ Amazon UK)
CPU Cooler: Thermalright Assassin King SE ARGB 66.17 CFM CPU Cooler  (£26.00 @ Computer Orbit)
Motherboard: ASRock B550M Phantom Gaming 4 Micro ATX AM4 Motherboard  (£88.55 @ NeoComputers)
Memory: G.Skill Sniper X 32 GB (2 x 16 GB) DDR4-3600 CL19 Memory  (£75.43 @ Amazon UK)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£87.98 @ Scan.co.uk)
Case: Corsair 4000D Airflow ATX Mid Tower Case  (£82.00 @ Computer Orbit)
Power Supply: Corsair RM750 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (£115.00 @ Computer Orbit)
Total: £597.86
Generated by PCPartPicker 2023-09-12 20:53 BST+0100
Is this a prebuilt?
Looks fine except for the RAM.  1x32GB is unacceptable.  2x16GB is the way to use dual channel RAM properly.
Is the thermal paste being applied?  I am reading this as a prebuilt, but thermal paste is already on the CPU Cooler, so you don't need any extra.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134525
Important: RAM should be two 16GB modules. Buying separate thermal paste for a stock cooler will be pointless.
Picky: The 5500 has relevant drawbacks from the 5600, so observe pricing on both carefully. Motherboard could be better (MSI Pro / Gaming Plus).
the pc guy
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134528
Just now, Dedayog said:
Is this a prebuilt?
You are 100% sure that it's just the ram? (It has thermal paste) I'm kind of desperate as I ordered a custom pc and apparently it's PSU is insufficient and that there will flat shutdowns and bsod. I can still change the order a bit to fix it
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134530
Thanks, I'm aware that 2 Is better than one. I did much research before I went through and purchased
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134533
RAM and thermal paste.
PSU is fine, plenty of power and Corsair CXM is a good one even if it's Bronze.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134535
You're intentionally buying 1 RAM stick?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134537
What does this mean?
Please explain.  Did you buy a previous PC and this is a replacement?
Why  didn't you just buy a new PSU, if there will be issues?  Who told you the PSU is insufficient?
I am not following your thought process here.  If you can change the order, change the RAM.   Don't be ashamed, just fix it.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134546
I'll change the ram, pc specialist, heard of em? There is a forum and some well known community member who gives very good advice and they very experienced. They said the PSU will bring the whole system down causing bsod and flat line shutdowns which I take very seriously. They have also mentioned that the case, cooler (dunno which one) and drives are not "up for the job". And you guys are telling otherwise and trust both, I'm very conflicted and not sure who to listen too. I did so much research and some ltt before I ordered the custom pc. (I can still edit the order before they dispatch it)
Thank you for your time
Edited by Epicernie77
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134555
8 minutes ago, Epicernie77 said:
I'm ashamed of it, I am very aware I am missing out on performance unnecessarily
Just change it? You say you still can. I mean this is legit a up to 50% performance loss + in game stuttering being a given.
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134556
Damn, ok I will, I will, I wasn't expecting that much of a hit
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134559
Well yeah if the case is the full glass front one then yes it's bad airflow wise and should be changed.
Psu is fine. It's a pretty decent unit from a couple years ago will run a 2080ti no sweat.
Cooler is meh. No point in thermal paste it won't help a bit. A budget tower cooler will easily improve thermals and noise heaps. However the stock cooler is fine temp wise.
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134561
Depends on the game. For example battlefield 5 had a 45% performance loss when going single vs dual on a 5600x and stuttered so badly it was not playable.
If you have the option to start correctly then why not start correctly directly?
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134562
No, the PSU is fine.  It's a great unit.
Fix RAM, don't pay for thermal paste, and ignore the PSU.
There should be a review o the PSU here, by people who know shit...
https://cultists.network/140/psu-tier-list/
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134567
Or if you tell us your budget, we can help you spec a possibly better machine...
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134569
I got airflow case (mesh)
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134573
Bit much. You ok building your own?
Pc specialist the company I bought from, is building the custom pc for me. I'm only putting in the GPU cuz they had outrageous prices and not the ones I wanted. I watched many GPU tutorials, and I'm very comfortable with that.
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134580
Oh then you're about to have some fun!!!
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134585
Yup, I already have the GPU, it's in my desk drawer nesting in its packaging
Are you in the UK?  I see pounds.  Need to know where to shop.
For 800 pounds, without a GPU, you have a really decent amount of money to play with.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1531112-advice-for-my-computer/#findComment-16134593
