Hi guys, so I am currently looking for fans for my H100 (old I know, was planning to upgrade but didn't have funds) which is cooling my 3960X... Here is the problem, I am currently using the 2 stock fans that come with the H100 which in my opinion are like jet engines, always have my fan controller on my NZXT Phantom 820 set to low as they are soo loud but that then makes my PC really hot.
Here is my dilemma, I can get 4 of these http://www.amazon.co.uk/gp/product/B00F6S0XJO/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1 for the price of 1 Noctua NF-F12.
Should I get these, put my H100 in push - pull and use the fan controller to turn them down or should I just spend extra money and get 2 NF-F12's?
Any help would be great.
Cheers, Paddy.
https://linustechtips.com/topic/153059-help-me-decide/
Those Corsair fans should be fine, but do take into account that they will not be completely silent.
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/153059-help-me-decide/#findComment-2043875
if you're putting that on a h100 then I'd suggest buy 2 of those and 2 of the SP120 ones (these you put on your h100).
I have the ap121 and 120 (these has most in stock) but I love t hem just plug them on 7V and forget about it. and it's not that noisy at 12v too.
Live your life like a dream.
https://linustechtips.com/topic/153059-help-me-decide/#findComment-2043923
It's £10.80 for 2 of the AF-120's so it would be £21.60 for 4 whereas it is like £19 for 1 Noctua NF-F12.
Might just get the 4 AF-120's and run them in push pull at lower speeds for noise :P
Can anyone recommend good thermal paste? As I have had my H100 for like 2 1/2 years and I think it really needs replaced :P
https://linustechtips.com/topic/153059-help-me-decide/#findComment-2043939
don't get AF120s for a radiator they are bad for them for radiators get SP120s not AF120s
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/153059-help-me-decide/#findComment-2043956
common misconseption. allthough they work worse in push, in pull ALONE they work fine. they are often used in push pull in fat rads.
they work fine but SP120s will be better than the AF fans
https://linustechtips.com/topic/153059-help-me-decide/#findComment-2043984
