Budget (including currency): £320
Country: England
Games, programs or workloads that it will be used for: Minecraft/streaming
Other details
Ryzen 5 1600x £30-£40
AMD Wraith Stealth Socket AM4 £28
Amd rx 580 £70
16gb patriot ddr4 ram  £25
msi am4 motherboard £40
Lexar NM620 512GB SSD £25
technoware 550w psu £20
Aerocool CS-107 v2 Mini Tower Case - Black £29
thermal paste £2
Total is £269 so far, i just need to get a monitor, minecraft java and a keyboard with the rest of the money and i need help to pick them.
Btw I cannot go over my budget at all.
https://linustechtips.com/topic/1528937-building-my-first-pc/
Should come for free with CPU if sold together as original. If buying separate, better buy a normal tower cooler for the same price than a downdraft one. Same price but better than if you have to BUY the included fan again. Here is Another one.
Amd rx 580 £70
Have a look at 1660 series. Should play a bit better. 1660, 1660TI and 1660 Super. They go for £40-£100 on auctions. Might be worth for you to fight out some bets over the space of a few weeks.
MAIN: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - Antec HCG Platinum - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's Mackie CR8S-XBT
Current build on PCPartPicker
HTPC: Ryzen 7 2700X - BeQuiet! Shadow Rock 3 - STRIX X570-F - 3200MHz 32GB Corsair Dominator - 250GB Exceria boot - 500GB SN730 - 1TB Sandisk 3D - 4TB HDD - Limited Edition Vega 64 - Corsair RM750x 80+ Gold - North - Alphacool Apex Stealth Metal - BeQuiet! Light Wings
SetupHisense 55E7NQ - Hisense HS205G
HTPC on PCPartPicker
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117919
Could i use a 1060 instead because im not that good at bidding and its cheaper to just buy
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117926
You can always buy something cheaper straight away but I strongly recommend bidding. A goldmine. All you do is find a 1660 you like, put the max you're willing to pay, lets say £70 and then you wait till the timer runs out. You either win at a price >£70 or you don't. Money never left your account in the first place.
Have a look at this goldmine. if you're lucky you could snag This combo for super cheap.
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117928
ahh ok thanks
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117937
Looking at the pheripherals you need and  minecraft, you have literally no money to play with. All for like £50. In the meanwhile get the Nokia phone of the keyboard world, K120 until you can upgrade again. All membranes are the same and this one can survive a nuclear blast. It'll last you at least.
Again, auctions are your only answer. Sit and only snipe deals. Found this AOC offer.
Edited by venomtail
IGNORE THE DELL broken LISTING
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117938
Just now, venomtail said:
Looking at the pheripherals you need and  minecraft, you have literally no money to play with. In the meanwhile get the Nokia phone of the keyboard world, K120 until you can upgrade again. All membranes are the same and this one can survive a nuclear blast. It'll last you at least.
Again, auctions are your only answer. Sit and only snipe deals. Found this AOC and this Dell offer.
thank you you are super helpful
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117942
BTW ignore the Dell that's broken I didn't spot that.
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117947
12 minutes ago, Average Fallout Player said:
yea oh and i do not have the money yet im selling something to get the money for it so i could get a bigger budget im not sure
So if this is an endeavor that will take you a long period of time buying parts, more reason for you to sit and grab great auctions. Not only are there many variations on the used market for what parts to buy, many even sell combos, some used PC's.
Could buy a used PC, buy a GPU separate, here is another one. Could always grab a combo and fill in the gaps that are missing(this one's over budget but you get the idea).
Again, time is on your side so over a period of time so find great auctions and you'll save yourself a ton of money. Stay vigilant for all listings and read the details. Chances of buying a dud are low and even if you do, it'll be only a minor setback and not a game over.
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16117957
Thank you so much
https://linustechtips.com/topic/1528937-building-my-first-pc/#findComment-16118947
