First Open Loop Build, From Scratch USD3000
Open loop is pretty much not worth it in this case. Dont waste your money and lose out on performance. Get the 13900k and 4090 for the same price. Get a good quality AIO thats 360mm and get it to fit your looks. If you are gonna spend that kind of money, get the most out of it.
if you were just gaming id consider the 7800x3D, but im not sure how well the drivers and such are for the audio stuff. Youd have to look up what your specific program prefers.
Case wise it really makes no sense to spend a LOT when your hardware suffers.
WD SN 850x will be more then enough, could get a 2 TB main drive and then a Samsung 970 EVO 2TB as a secondary.
PSU 850W-1000W would be the correct wattage.
RAM yeah a 2x32 6000-6400 kit will be more then enough.
