11 minutes ago, BONTO5160 said:
so I have an RTX 3060 Ti with a i5-12400F and 32GB RAM and it should run smoothly with 1440p ULTRA but I only have 60FPS on Miramar instead of 100 and on Vikendi I only have 80 instead of 100+
How do you know you should have more FPS? What is your source.
https://linustechtips.com/topic/1528240-pubg-low-fps/#findComment-16111228
as said above, what are your sources for these expectations? pubg isn't highly demanding in my experience, and i would expect better fps with your specs, but there are more variables than that. the main one imo is what graphics settings are you running in game? if your indeed running every setting maxed, try adjusting them to get your fps closer to where you want it to be. my pc has better specs, and im not sure my fps would be what you are expecting with every setting fully maxed(will try in a bit out of curiosity).
https://linustechtips.com/topic/1528240-pubg-low-fps/#findComment-16111347
Good joke. A low-end GPU and a barely mid-range CPU in a 2017 game that has been severely updated, on the Unreal Engine 4, on the newest map remaster...
Adjust your expectations. Or upgrade.
Also, PUBG isn't meant to be run on Ultra, it's a competitive game, just run it on very low with Anti-Aliasing on High and textures on High or Ultra.
90% the graphics fidelity, 90% the performance of everything on ultra low.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1528240-pubg-low-fps/#findComment-16111349
8 hours ago, BONTO5160 said:
any videos with the same specs on yt
Miramar was updated a couple of weeks ago. New graphics means different performance.
https://linustechtips.com/topic/1528240-pubg-low-fps/#findComment-16112285
