Depending on the prices there, here are some great silent switches
Cherry MX Silent
Boba U4
Kailh Midnight Pro Silent (available in tactile and linear)
Keychron Silent K Pro (the cheapest, but the 'loudest' among all of them)
Tech tips:
Although switches are the main source of the keyboard sound, but the sound will be determined on your overall keyboard build (keycaps, dampening foam, mounting system, etc). So keyboard without any foam and PCB contact with case will sounds louder than keyboard with a lot of dampening and gasket mounted PCB
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1527949-keyboard-help/#findComment-16108099
3 hours ago, TNichol said:
how cheap i could get everything else brand new for
What do you mean by everything else in this context? The keyboard chassis and the keycaps? Or just other switch alternatives that are cheaper? Because trust me, a huge chunk of Wuque products are annoyingly overpriced sometimes.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1527949-keyboard-help/#findComment-16108206
Found this by accident yesterday:
Another contender I just found: https://www.monsgeek.com/product/mg108w-kit/
PCB is 5-pin, so should be compatible with any MX style switch. I don't know about any potential shipping/import costs to Canada, nor do I have any idea about the quality. I just thought that 29USD seems rather affordable for a full-size kit. Plus I think they might also have a TKL version.
You will need a set of keycaps though, which will cost you something between 20USD and 200USD, depending on what and where you buy it.
My safe recommendation would be a Keychron V series, which range typically from ~70USD to ~110USD for the various barebones versions, plus shipping, keycaps etc. Keychron also has a canadian website you can order from, so I assume shipping/import taxes wouldn't be an issue.
https://linustechtips.com/topic/1527949-keyboard-help/#findComment-16108333
15 hours ago, TNichol said:
Hi There!
I was wanting to have these ws silent linear switches, but was wondering how cheap i could get everything else brand new for.
I live in canada btw.
You mentioned you wanted a TKL in your last post.
Here's this TKL from Glorious on Amazon.ca for $70
https://www.amazon.ca/Glorious-Mechanical-Keyboard-Tenkeyless-Gaming/dp/B01MSVHZTT/
and then just buy whatever keycaps look nice. btw, that kit is North-Facing LED, so it is incompatible with "Cherry Profile" keycaps.
You could also just make life a little simpler and buy a completed TKL and replace the switches since that's kind of the idea behind a hot-swappable board anyways.
https://www.amazon.ca/Glorious-GMMK-White-Mechanical-Brown/dp/B0877BDC7P/
https://www.amazon.ca/Keychron-Mechanical-Keyboard-Double-Shot-Keycaps/dp/B0C59558HY/
https://www.amazon.ca/RK-ROYAL-KLUDGE-R87-Switch-White/dp/B0C9DLWDFT/
https://www.amazon.ca/RK-ROYAL-KLUDGE-H81-Mechanical/dp/B0B9GLJSZX/
and here is Keychron's Canada website with keyboards in ascending price
https://keychron.ca/collections/all-keyboards?sort=price-ascending
Edited by saintlouisbagels
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
https://linustechtips.com/topic/1527949-keyboard-help/#findComment-16108956
