So yeah, ive got a broken fan blade on my MSI GTX 680 PE OC (Lightning). I found it at the bottom of my case one day when it was removed. Pretty sure the case hit it but come on, ive had a few cards in my days and have never had an issue of a fan blade breaking off. So how do i go about fixing this? Glue? RMA? Is it even RMAable? Ive only had it for a few months and it would suck to have to buy a new card in a few more months due to a dead fan because of the vibration beiung produced.
Also, im not willing to break off another fan blade to balance the weight so please dont suggest it!! Thanks guys.
https://linustechtips.com/topic/15272-broken-fan-blade/
watercool the card?
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/15272-broken-fan-blade/#findComment-170792
Check to see if your warranty covers it. I had the same issue with my GTX 580 from Palit a while ago, but it wasn't covered. If it's not covered glue the fan blade back on to the best of your abilities, and it should be fine after that. Just remember not to run it without the blade as the vibration can degrade the fan bearing quickly and destroy the HDD.
https://linustechtips.com/topic/15272-broken-fan-blade/#findComment-170863
My problem is kinda close but different. I had a x1300 pro back in the day and the heatsink melted YES it melted and it only got to like 60-70oc but half was like a oreo dipped in tea and the rest was a mushy mess on the bottem of the case
Listen if you care.
https://linustechtips.com/topic/15272-broken-fan-blade/#findComment-170951
I would RMA it instead of trying to fix it yourself and having the chance of screwing it up.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/15272-broken-fan-blade/#findComment-171984
Thats what im thinking. The MSI website doesnt really explain a whole lot on whats coverd and what isnt so i suppose i should submit an RMA and hope for the best.
https://linustechtips.com/topic/15272-broken-fan-blade/#findComment-175751
