10 minutes ago, ThatComputerNerd said:
On my build, I originally wanted to get the AMD Ryzen 7 7700x and pair it with the Noctua NH-D15 for cooling it down. However I was reading online that they're not compatible. Is this true?
This is not true. I use my NH-D15 with my 7700x 🙂   You will need to use the AM4 mounting bracket that come with the NH-D15. Using the grey motherboard standoffs, not the white.
This is my email to Noctua regarding this as well.  Read bottom up 🙂
Hope this helps
https://linustechtips.com/topic/1526696-proccessor-air-cooler/#findComment-16091514
