Haelp! Could not create the Java Virtual Machine?
Go to solution Solved by Guest,
Fresh install Java?
I get this error when I try to open minecraft:
Error: Could not create the Java Virtual Machine
Error: A fatal exception has occured. Program will exit.
I looked up the error, and did the Java variables in my system environment variables. HAELP!
