Hi, I am aiming to build a remotely-accessible PC and would appreciate any insight into my hardware specs
Budget: ~$500 USD
Country: US
Games, programs or workloads that it will be used for: TrueNas CORE (Time Machine backup), remote development server, git repository, media server
Other details: Will be run headless (no peripherals / monitor)
I envision running TrueNas CORE with a Time Machine block to backup my Mac, a Debian VM for remote VSCode development, and media server. The system must be reliable so that the data are not corrupted / lost.
Based of the recent Building a $500 Intel Gaming PC - 2023 video from May 2023, I am currently considering the following (see: https://pcpartpicker.com/list/yj9ZxH):
  • AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor
    • 6 Cores enables dedicated cores for VMs vs 2 core intel i3
  • MSI A520M-A PRO Micro ATX AM4 Motherboard
  • Kingston Fury Renegade RGB 8 GB (1 x 8 GB) DDR4-3600 CL16 Memory
    • Potential to add 2nd stick in future; can replace for up to 64 gb
  • 2 x Western Digital Blue 4 TB 3.5" 5400 RPM Internal Hard Drive
    • "server-grade" disks
    • RAID 1 mirroring
    • main storage for next 5-10 years?
  • Kingston NV2 250 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
    • Boot drive
    • caching?
LTT also recommended:
  • DIYPC F2 MicroATX Mini Tower Case
  • Thermaltake Smart 500 W 80+ Certified ATX Power Supply
1. Many have casted doubts on the reliability of the PSU; should I be concerned, and if so, can you recommend an alternate? I believe 312W is sufficient for these components.
2. Is there a bigger / better case that can accommodate all of the drives with adequate ventilation?
3. Alternate HDD recommendations?
4. Is it possible to use the boot drive as a fast SSD cache? Will I need to partition the drive?
5. Any other advice / warnings?
Thanks!
https://linustechtips.com/topic/1523857-first-pc-networked-storage-device/
It's not amazing and for the price you can get better
Yes
These
Seagate EXOS Enterprise 4 TB 3.5" 7200 RPM Internal Hard Drive (ST4000NM0035) - PCPartPicker
Or these
Seagate BarraCuda 4 TB 3.5" 5400 RPM Internal Hard Drive (ST4000DM004) - PCPartPicker
Yes
No
Your build's decent but the 5600x doesn't have an igpu and that nv2 is a terrible ssd
Go for this build instead
PCPartPicker Part List: https://pcpartpicker.com/list/skQ2Fs
CPU: Intel Core i3-12100 3.3 GHz Quad-Core Processor  ($114.99 @ Amazon)
Motherboard: ASRock B660M Pro RS Micro ATX LGA1700 Motherboard  ($94.99 @ Newegg)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($29.97 @ Amazon)
Storage: Samsung 970 Evo Plus 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($34.99 @ Amazon)
Storage: Seagate BarraCuda 4 TB 3.5" 5400 RPM Internal Hard Drive  ($67.99 @ Newegg)
Case: Deepcool MATREXX 40 MicroATX Mini Tower Case  ($44.99 @ Amazon)
Power Supply: Thermaltake Toughpower GX2 600 W 80+ Gold Certified ATX Power Supply  ($64.98 @ Amazon)
Total: $520.89
Generated by PCPartPicker 2023-08-04 04:04 EDT-0400
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
3 hours ago, fpoyfnc said:
media server
Live transcoded to your phone/TV or do you want this to just be a source server with 2nd system as a head transcoder? Because if its the former im more inclined with @filpo but without running an SMR drive.
Storage: Silicon Power P34A60 512 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($22.97 @ Amazon)
Storage: Seagate EXOS Enterprise 4 TB 3.5" 7200 RPM Internal Hard Drive  ($65.00 @ Amazon)
Case: Fractal Design Core 2300 ATX Mid Tower Case  ($66.45 @ Amazon)
Total: $524.35
Generated by PCPartPicker 2023-08-04 07:23 EDT-0400
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I would recommend having a separate drive for cache, because cache drives are re-written a lot and you do not want your boot drive failing, because if your cache drive fails you will just see a performance hit, but if your boot drive fails then you will see a system failure and might have to completely re-do the system. Also, if you are doing things like video editing then I would recommend having a drive (or raid array) dedicated to rough storage and one for finished work.
Main "Rig"=HP 11A G6 EE
Android Tablet
Raspberry PI Zero W 2
If you have any fun ideas for things for me to do with my PI, send me a direct message.
I plan to upgrade within a few months to a proper computer.
