First PC build advice
Go to solution Solved by jrd,
9 minutes ago, Why_Me said:
I'm not sure if they are talking about the LGA 1700 bracket or the fact that cooler doesn't fit all boards with large heatsinks due to the fact that cooler is BIG.  Your safe with this cooler.
https://www.deepcool.com/products/Cooling/cpuaircoolers/GAMMAXX-AG620-Dual-Tower-CPU-Cooler-1700-AM5/2022/15900.shtml
https://pcpartpicker.com/product/GCjBD3/deepcool-ag620-6788-cfm-cpu-cooler-r-ag620-bknnmn-g-1
DeepCool AG620 Dual Tower CPU Cooler $49.99
thank you for all the help. I think im gonna pull the trigger on your build. wish me luck!
Budget (including currency): 1700-2000 $USD
Country: USA
Games, programs or workloads that it will be used for: Singleplayer games, FPS shooters
Other details
https://pcpartpicker.com/list/8Pg3cb
I had help building this list, but if anyone has any advice and recommendations those would also be appreciated. I would also like to find another motherboard that is currently in stock. This is my first pc build so the help is greatly appreciated
Edited by jrd
https://linustechtips.com/topic/1521359-first-pc-build-advice/
Country: USA
Other details
What resolution are you going to be gaming in?
PCPartPicker Part List
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($240.99 @ Newegg)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($36.90 @ Amazon)
Motherboard: Asus TUF GAMING B650M-PLUS WIFI Micro ATX AM5 Motherboard  ($219.99 @ Amazon)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  ($95.99 @ Newegg)
Storage: Samsung 970 Evo Plus 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($95.89 @ Amazon)
Video Card: ASRock Phantom Gaming OC Radeon RX 7900 XTX 24 GB Video Card  ($959.99 @ Newegg)
Case: Fractal Design Pop XL Silent ATX Full Tower Case  ($73.98 @ Newegg)
Power Supply: Thermaltake Toughpower GF1 PE 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Total: $1833.72
Generated by PCPartPicker 2023-07-23 18:24 EDT-0400
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046176
Country: USA
Other details
What's your resolution or is a monitor to be included in the budget?
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046187
Here's a case with better airflow so that your components don't cook. The 120mm fan goes inside the back of that case for a rear exhaust fan. Use Windows 11 with these Intel 13 gen cpu's.
https://pg.asrock.com/Graphics-Card/AMD/Radeon RX 7900 XTX Phantom Gaming 24GB OC/index.asp#Specification
Recommended PSU: 1000W
CPU: *Intel Core i5-13600KF 3.5 GHz 14-Core Processor  ($285.99 @ Newegg)
Motherboard: *MSI B760 GAMING PLUS WIFI ATX LGA1700 Motherboard  ($159.99 @ Amazon)
Memory: *G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  ($109.99 @ Newegg)
Case: *Fractal Design Focus 2 ATX Mid Tower Case  ($79.98 @ Newegg)
Power Supply: *Corsair RM1000e (2023) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($162.25 @ Amazon)
Case Fan: *ARCTIC P12 56.3 CFM 120 mm Fan  ($9.99 @ Amazon)
Total: $1900.97
Generated by PCPartPicker 2023-07-23 18:53 EDT-0400
A better look at those components.
https://www.msi.com/Motherboard/B760-GAMING-PLUS-WIFI
https://www.intel.com/content/www/us/en/products/sku/230494/intel-core-i513600kf-processor-24m-cache-up-to-5-10-ghz/specifications.html
https://www.fractal-design.com/products/cases/focus/focus-2/black-tg-clear-tint/
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046203
Total: $1833.72
I will be using mostly 1440p, and already have a decent 165hz HDR monitor. Thank you for the advice I appreciate it.
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046213
Total: $1900.97
Thank you for the advice it is greatly appreciated! I'm curious what would the difference be between a micro ATX and ATX? why would i choose one over the other?
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046215
The ATX boards have a few more PCI slots which aren't always needed.
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046217
Thank you. On your recommended build from PC part picker, it notes the Thermalright CPU cooler may require a seperate mounting adapter to fit the MSI B760 motherboard. Would I need to worry about that?
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046237
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046245
https://linustechtips.com/topic/1521359-first-pc-build-advice/#findComment-16046254
