Here is the list of parts I plan to use for my custom built hackintosh computer...
http://pcpartpicker.com/p/3JuMr
But... I need help, first
  1. Are my parts all compatible for a hackintosh?
  2. I plan to use this as an editing computer, is there a better setup for the same price
Thanks!
Also, I will do some 3D should I go AMD or Intel?
Thanks again!
https://linustechtips.com/topic/152080-need-help/
Well at least get a 7200 RPM's hard drive, the 5400 is way slower, also go down from 1000 watts to 860 like the guy above said, 860W can run 2 770's and a 4770k easily so there's noneed for 1000 if you're not planning on 3-way SLI which I wouldn't recommend. Otherwise it looks fine! :)
Emmh... Maybe consider killing yourself before you talk to me?
Pople on this forum though some of them had a brain, turns out, no.
https://linustechtips.com/topic/152080-need-help/#findComment-2031010
Do get Intel for a hackintosh, please!
AMD and Hackintosh is not a good idea (at least it used to be...).
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
https://linustechtips.com/topic/152080-need-help/#findComment-2031065
Thanks!
Thanks again!
Here is a Hackintosh Guide listing all of the compatible components.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
https://linustechtips.com/topic/152080-need-help/#findComment-2031181
