Weird Screen Issue.
Go to solution Solved by NextraMia,
Never mind, Had a weird "Shadow Control" ratio on so it go confused over black images.
Yo! I have a 1440p monitor aswell for youtube: "AOC AG273QZ"
It pretty much works fine unless i'm on some really specific pages like this "New Topic" page.
Basically my entire screen gets stripy and if I go into another tab, lets say... "Youtube" then the stripes
disappear. As it doesn't always happen I don't find it to be a super big deal, but despite me saying that i'll still say it's a bit annoying when it happens. When the stripes appear, if I hover over a link button of some sort or at least something clickable then the stripes almost disappear.
If you know a fix then gladly tell me them as i've never really looked into a fix nor have i really been able to figure out why it happens every now and then.
Pictures show the screen + icons on the bottom, 1. In the "Create New Topic" where icons and screen gets stripy, 2. On the "Profile" page on the website without stripes on icons nor screen.
CPU: AMD Ryzen 9 5950X ||| GPU: Gigabyte GeForce RTX 3090 GAMING OC ||| Motherboard: Asus Rog Crosshair VIII Dark Hero ||RAM: G.Skill Trident Z DDR-4400 CL16 ||| PSU: Corsair HX Platinum 1200 W 80+ ||| Case: Lian Li - O11 Dynamic Evo ||| Storage: 2x Samsung 980 Pro 2 TB NVME SSD ||| Cooling: (CPU: EKWB RGB 360 AIO) (Case-Fans: Lian Li SL-120 Infinity)
https://linustechtips.com/topic/1519031-weird-screen-issue/
https://linustechtips.com/topic/1519031-weird-screen-issue/#findComment-16030462
