Maximum display with display adaptor.
Go to solution Solved by UnknownEngineer,
Sorry for the delay in replying.
So that means I need to buy a monitor with DisplayPort input for the highest resolution.
Any recommendations for 1080p monitor (I prefer Samsung) ?
For 1080P HDMI is all you need, DVI-D will work as well.
VGA is the only one you need to avoid.
What can each run @60Hz
1080P HDMI and up.
1440P DVI-D and up (could be 1600P i can't remember)
up to 4K DisplayPort
VGA can only do 800x400 @ 60Hz
As for actual recommendations on displays, first you need to decide what size do you need/want. Also do you want crazy fast response times and refresh rates, or do you want better color and so on.
DVI-D Possibly, i am not quite certain.
VGA? If you wont mind each frame taking 10 seconds to arrive to the display, then yes. Without any modding, NO.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
You won't be able to get to display port levels of resolution and refresh using a DVI as compared to display port. but I think DVI can push 1920 by 1200 at 60hz if i'm not mistaken. That's about the max for it. And as for VGA just forget it haha.
My Rig "Corsair air 540, MSI Z87-G45, i5 4670k, EVGA ACX 780, Gskill sniper 2x8gb 1866 memory, Corsair CX500m modular 80+ bronze, corsiar h100i, toshiba 1.5tb HDD." / Peripherals "Acer H226HQLbid Black 21.5" (Main monitor), Acer S200HLAbd Black 20" (auxiliary), Razer blackwidow ultimate 2013, razer naga 2013, razer goliathus 444x355 speed edition, Sennheiser HD8 DJs"
Single link DVI supports up to 1920x1200 @60Hz, Dual link can handle up to 2560x1600 @60Hz. I'm using a dual link port for a monitor at 1920x1080 @120hz Hz. If you want to use a resolution that requires dual link DVI, you would need an active DP-DVI converter which are quite expensive compared to the single link ones.
CPU: i5 2500k @ 4.5 GHz; GPU: MSI HD 6950 Twin Frozr; RAM: 16 GB DDR3 1600 MHz; SSD: 250 GB  Samsung EVO; Storage: 2x 1TB, 1x 2TB, 1x 3TB; PSU: Corsair AX750; Peripherals:  2x LG 1080p Monitors; Logitech G500; Corsair K70;
DisplayPort adapters to VGA and DVI become equivalent output of VGA and Single-Link DVI. Whatever those maximums are, it will be the same if they are from a DisplayPort adapter as it is with just a native connection.
1080P HDMI and up.
