Red DRAM Light on Startup
Go to solution Solved by DontBeSillyWrapYourWilly,
Well if i understood you correctly that is pretty much what's supposed to happen. System is running through checks to see if everything is fine , one of those is RAM check , during which RAM light is on.
Hey y’all,
I recently upgrade my motherboard, cpu, and ram to am5 and ddr5. Everything is working pretty well, however when I turn on the pc the dram error light on my motherboard turns on for the duration of startup, but then turns off once I’ve booted into windows and the pc runs pretty much completely fine. Anyone know why this light may appear? I want to make sure there’s not a large underlying issue that will cause problems later. Thanks!
https://linustechtips.com/topic/1516295-red-dram-light-on-startup/
15 minutes ago, ShinyKyogre said:
Hey y’all,
my motherboard cycles trough all error leds and then turns on
maybe its same with you, for me its completely normal
Dont forget to mark as solution if your question is answered
Note: My advice is amateur help/beginner troubleshooting, someone else can probably troubleshoot way better than me.
- I do have some experience, and I can use google pretty well. - Feel free to quote me I may respond soon.
Join team Red, my apprentice
STOP SIDING WITH NVIDIA
Setup:
Ryzen 7 5800X3DSapphire Nitro+ 7900XTX 24GB / ROG STRIX B550-F Gaming / Cooler Master ML360 Illusion CPU Cooler / EVGA SuperNova 850 G2 / Lian Li Dynamic Evo White Case / 2x16 GB Kingston FURY RAM / 2x 1TB Lexar 710 / iiYama 1440p 165HZ Montitor, iiYama 1080p 75Hz Monitor / Shure MV7 w/ Focusrite Scarlett Solo / GK61 Keyboard / Cooler Master MM712 (daily driver) Logitech G502-X (MMO mouse) / Soundcore Life Q20 w/ Arctis 3 w/ WF-1000XM3
CPU OC: -30 all cores @AutoGhz
GPU OC: 3Ghz Core 2750Mhz Memory w/ 25%W increase (460W)
It does briefly flash the CPU light and then holds the DRAM light when it begins to boot. What motherboard/brand are you using? I have an Aorus b650m elite
im using an asus b550 f
Setup:
GPU : RTX 3070 Gaming X TRIO | CPU : Ryzen 5 7600 \ COOLER : Deepcool AK620 | MOBO : ASUS TUF Gaming B650 Plus | RAM : Corsair Vengeance RGB DDR5 16GBx2 6200 MHz \ Storage : Samsung 970 EVO Plus M.2 1TB \ PSU : Corsair TX750M | CASE : Be Quite! Pure Base 500DX Black
That would make sense then, thanks for letting me know.
