that is pretty much the standard layout in many cases.
when air flows dust does not settle but cooling fins and dust filters can accumulate and catch particles that overtime can build up
Worst case is a PC and someone who smokes as tar and nicotine leave a sticky residue on surfaces where dust can stick. For a PC that's not good as people who have their PC on the desk the front fans simply pull the smoke directly into the PC.
Large amounts of gathered dust is generally a sign of neglect and zero maintenance.
Myself I dont use any dust filter but I check my pc and clean about every 3 months.  95% of all dust dirt fluff is actually caught on the leading edge of the front case fans and i use a soft round paint brush to clean them
https://linustechtips.com/topic/1515809-negative-air-pressure/#findComment-16006788
3 minutes ago, AlbertoSQ said:
Hello, I was just wondering if 2 intakes(at the front), 1 fan exhaust(at the back) and 2 cpu liquid cooler exhaust fans(at the top) would cause any large amounts of dust gathering?
Are all the fans the same?
You can individually set the fan speeds to configure the airflow you want.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1515809-negative-air-pressure/#findComment-16006810
Negative vs positive pressure only matters if you have filtration on the intake fans. And if you have filters, make sure you clean them often. There's a reason workstations and other office computers usually don't have filters, because blocked airflow is worse than dust!
https://linustechtips.com/topic/1515809-negative-air-pressure/#findComment-16008636
