Airflow Advice
5 minutes ago, MrMyth said:1) Does this airflow make sense? I would think so, because it gets fresh, cool air over the CPU and GPU, and pulls out hot air on the bottom and back (bottom has enough clearance)
This goes against convection (warm air rises)
6 minutes ago, MrMyth said:2) Would it be a lot smarter, to have the radiator below the top fans, if I use them as intake? Will the amount of air pushed/pulled through be significantly more or better?
flip the radiator fans to push air through the rad instead of pulling it through
7 minutes ago, MrMyth said:3) Is this a stupid design, because hot air tends to rise up, and the fans won't be able to pull everything through?
It is sub-optimal at best I guess
7 minutes ago, MrMyth said:4) If it is flawed, what would be a decent airflow setup with these 10 fan spots?
I'd prefer if as many fans as possible had the intake side visible in the case, for aesthetics ofc xd
side fans - intake
bottom fans - intake
top fans - out
rear fan - out
Note: this is, I believe the most optimal setup for your 10 fans.
