PC stuck at CPU debug led!!!
1 hour ago, Rafid Rahat said:Everytime I press the power button the computer is stuck at CPU debug led.After 3 or 4 times forcefully shutting it down and turning it on, it starts displaying.I cleaned the PC parts and checked if the CPU pins were alright.Found no problem there.At first it was resolved after updating the bios everytime.But after sometime that stopped working too.This has been going on for an year.My led for the power button has also stopped working. I think this is related to power consumption but I can't be sure. Please any help would be appreciated. Thank you.(Note: I did try to cable manage so I might have messed up somewhere)
Specs:
Processor:Ryzen 5 3600
MB: Msi B450 mortar max
Ram:2x8 GB 2666MHz Juhor
Gpu: Asus TUF 1650 oc 4GB
Psu: Gigabyte P650b 650 Watts Non modular
Case: Deepcool Mattrexx 55 mesh
Monitor : LG 22MK600
Aha my friend. Made the same mistake kinda... When you were cable managing I think you didn't press both the 24 pin and cpu 4 pin cables in far enough on the motherboard. Try that and see how that goes!
