http://www.ncix.com/detail/asus-mx279h-27in-widescreen-led-c7-79445-1049.htm
i wish this was vesa compatible but its not. can i make it?
If theres no mount on the back, I can't really think of a way to do it besides drilling wholes in the back. Couldn't you get a similar TV with vesa?
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/150990-vesa-mount-adapter/#findComment-2016705
i already have it
if you are reading this you are wasting valuable time and should maybe rethink your life choices.
https://linustechtips.com/topic/150990-vesa-mount-adapter/#findComment-2017315
