Help with my build please!
10 minutes ago, Hooondy said:GPU: 4070Ti or 7900XT? Cost differnece is negligible. My thoughts, Ray Tracing & DLSS vs 20Gb VRam, what am I missing to make a decision? FYI COD performance is important to me.
you should be able to get a 4090
10 minutes ago, Hooondy said:GPU: If 4070Ti, is there any difference between GeForceRTX 4070 Ti WINDFORCE OC and the GeForce RTX 4070 Ti EAGLE OC (rev.1.0)? At all?!
no not much, maybe a slightly higher boost on the windforce but overall no
11 minutes ago, Hooondy said:GPU: Should I care about Ray Tracing? At all?!
your decision. I don't use it but you could
11 minutes ago, Hooondy said:GPU: Should I care about whether my monitor choice is GSync, FreeSync or ActiveSync? (Assuming RTX4070Ti choice)
if you worry about tearing then sure, most monitors come with g sync compatible certification so you should be alright
12 minutes ago, Hooondy said:GPU Should I care about GSync vs GSync compatible?
g sync means its officially certified whereas g sync compatible is a freesync monitor that can do g sync
12 minutes ago, Hooondy said:RAM: Best RAM to pair with the 7800X3D? I've read 6000Hz CL30 is best. But Supplier contacted me today with the following:
"We've been checking through the chosen components and have noticed that, even though RAM capable of up to a 6000MHz frequency has been added to this order, due to how new DDR5 still is, it is unfortunately a possibility that the system will not be able to reach a stable 6000MHz memory frequency as yet with 4 sticks. That is likely to change in the near future once newer BIOS updates are released to better support higher memory frequencies.
Please let me know if you're happy for our team to clock the memory at its highest stable frequency, or if you'd like to downgrade the RAM to possibly make a saving on its cost."Does he know what he's talking about? What should I do?
tbh it sounds like bullshit. I would go for 6000 CL30 and if it doesn't work then raise the subtimings to cl32
13 minutes ago, Hooondy said:RAM: Am I right in saying 2 x 32Gb is a better combination than 4 x 16Gb for this RAM, on this mobo, with this CPU? If not, then what?
yes your right, better for compatibility
