My first pc build
Go to solution Solved by filpo,
Just now, Invisible jedi said:
about getting a motherboard that i may have to update before i can even use. I honestly have no idea how to do that.
it should work anyways but just work better with a new bios update. Its really easy to do too using bios flashback
2 minutes ago, Invisible jedi said:
Also could you explain the choices here a little bit? I just want to understand how to pick parts better.
The ryzen 7 5700x cuz its the best price to performance 8 core cpu out there and you have to do video editing too so that's why
Thermalright PA120SE cooler cuz its the best cooler for the price nowadays
B550 tomahawk as its the best ryzen 5000 series mobo for about 230 aud
32 gigs of ram since your doing some productivity (such as video editing and for 'future proofing')
Storage since its the cheapest gen 4 1tb drive (but a 970 evo plus could be better for about 20 aud more)
6800 xt since its better than the 4070 and has more vram for the same price
power supply since its the highest wattage psu for the budget
case since its a really good budget case for the price
Budget (including currency): 2000 AUD
Country: Australia
Games, programs or workloads that it will be used for: OW2, HALO, as well video editing for a youtube channel i am starting.
Other details
ok so im building a gaming pc but i also want it to be able to do work like video editing and some light image and graphical design.
https://au.pcpartpicker.com/user/Invisiblejedi/saved/PXP7wP
Im really new to this, i havent owened a pc more involved than a gaming laptop. So yeah, complete newbee.
Im hopeing that i can get some feed back on my parts list and anywhere that i can save some money without compremising performance too much.
Upgradeability is a big plus for me. As i want to be able to keep this pc for many years. So id like to get atleast the bones of the new gen stuff, if possible. Again im not super sure how it all works but im learning fast.
https://linustechtips.com/topic/1507957-my-first-pc-build/
Country: Australia
Other details
your pc part list is private
But i would go for this one:
PCPartPicker Part List: https://au.pcpartpicker.com/list/xpCPjZ
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($299.00 @ Centre Com)
CPU Cooler: Thermalright Peerless Assassin 120 SE WHITE ARGB 66.17 CFM CPU Cooler  ($99.00 @ Amazon Australia)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard  ($239.00 @ Centre Com)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($108.10 @ MSY Technology)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($65.00 @ BPC Technology)
Video Card: XFX Speedster MERC 319 CORE Radeon RX 6800 XT 16 GB Video Card  ($898.22 @ Amazon Australia)
Case: Phanteks Eclipse G300A (1 Fan) ATX Mid Tower Case  ($99.00 @ PCCaseGear)
Power Supply: Thermaltake Smart BM2 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($109.00 @ Computer Alliance)
Total: $1916.32
Generated by PCPartPicker 2023-05-19 19:25 AEST+1000
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1507957-my-first-pc-build/#findComment-15947540
Total: $1916.32
Thanks for the sujestion. Altho i am a bit... unsure, about getting a motherboard that i may have to update before i can even use. I honestly have no idea how to do that.
https://linustechtips.com/topic/1507957-my-first-pc-build/#findComment-15947546
Total: £1040.95
https://linustechtips.com/topic/1507957-my-first-pc-build/#findComment-15947551
Thats great. I think im starting to understand this more. I have changed the parts list settings. I didnt even realise.
I had actually choosen the same cpu. Altho i went for a water cooling option. I dont really want it to be super loud (altho thats not the end of the world)
Also i went with a radion 6750 XT.
As will be needing to get a monitor and keyboard inside my budget also, i already have a mouse.
https://linustechtips.com/topic/1507957-my-first-pc-build/#findComment-15947563
btw air cooling is actually pretty quiet with this air cooler (thermalright PA120SE)
Also the 6750 xt is only a slight overclock over the 6700 xt so there's no point paying more for the 6750 xt imo
Edited build:
PCPartPicker Part List: https://au.pcpartpicker.com/list/7Cj93y
Video Card: Asus DUAL Radeon RX 6700 XT 12 GB Video Card  ($559.00 @ MSY Technology)
Monitor: Asus VG259QR 24.5" 1920 x 1080 165 Hz Monitor  ($299.00 @ PCCaseGear)
Keyboard: G.Skill KM360 Wired Standard Keyboard  ($102.12 @ Amazon Australia)
Total: $1978.22
Generated by PCPartPicker 2023-05-19 20:10 AEST+1000
What resolution? I put a 1080p monitor in that build but if its 1440p then get this monitor LG 27GN800-B 27.0" 2560 x 1440 144 Hz Monitor (27GN800-B) - PCPartPicker
Total: £1040.95
https://linustechtips.com/topic/1507957-my-first-pc-build/#findComment-15947573
Edited build:
Total: $1978.22
Oh the moniter doesnt matter at all. Im was only planning on getting the cheapest one i could and upgrading it in a few months after my wallet recovers.
This has been a big help. Thank you. Some slight tweaks and i think im almost ready to go.
https://linustechtips.com/topic/1507957-my-first-pc-build/#findComment-15947581
if you get a good one now you could spend later down the line
of course no problem and welcome to the forum
Total: £1040.95
https://linustechtips.com/topic/1507957-my-first-pc-build/#findComment-15947583
