Mini Itx build
On 5/18/2023 at 5:50 AM, 92 Honda Accord said:PCIe 5.0
You wont see any massive difference between 5.0 and 3.0 in games even those with DirectStorage, between the version its only .5 second delta in loading times in Forspoken. Having an nvme drive in the first place is already a huge clutch for DirectStorage supported title.
On 5/18/2023 at 5:50 AM, 92 Honda Accord said:DDR5-6400
AMD is super cagey above 6000, and do prefer lower latency RAM anyway. And id definitely pick up ram with EXPO profile below 1.3V due to the current SOC meltdown issue.
But yeah for 1080p this is a banger build.
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor ($449.00 @ Amazon)
Motherboard: MSI MPG B650I EDGE WIFI Mini ITX AM5 Motherboard ($289.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-5600 CL30 Memory ($104.99 @ Amazon)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($89.49 @ Amazon)
Video Card: Zotac Twin Edge OC GeForce RTX 4070 12 GB Video Card ($589.99 @ Newegg)
Case: Cooler Master NR200P MAX Mini ITX Tower Case ($464.99 @ Newegg)
Total: $1988.45
Generated by PCPartPicker 2023-05-19 03:15 EDT-0400
If you just game you can go and get AMD Radeon RX6950XT instead while you still can. That thing perform within 7900XT realm in 1080p.
