Intel Arc A770 power
Go to solution Solved by SorryBella,
49 minutes ago, Enhaler69 said:
yes but my pcie cable had 2 8pin connectors on it
Oh its those daisy chained ones huh? Whats the PSU? Its more doable that way but still suboptimal if its a modular PSU.
7 minutes ago, Jajo said:
You can always undervolt it to lower the power consumption, but do it properly because many tutorials show how to underclock it instead of an undervolt
Good luck doing it before Arc UI rework.
4 hours ago, Enhaler69 said:
Can the a770 be ran on one pcie cable with a split off
Nope. 1 8 Pin is 150W max, and A770 is a rated 225W card.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1506945-intel-arc-a770-power/#findComment-15940018
35 minutes ago, Enhaler69 said:
@SorryClaireyes but my pcie cable had 2 8pin connectors on it and it says that by default card is set to 190w with OC up 300w i wont be overclocking
Im running a tuf 3060 ti gddr6x on a daisy chain, it gets to 230w under load ,so far no problems so you probably good
https://linustechtips.com/topic/1506945-intel-arc-a770-power/#findComment-15940169
https://linustechtips.com/topic/1506945-intel-arc-a770-power/#findComment-15940179
https://linustechtips.com/topic/1506945-intel-arc-a770-power/#findComment-15940187
