External build not starting
Go to solution Solved by jd_guy17,
Fixed It
I have done a external build but something isn't working. I am not sure what isn't working but I think its the power supply as the motherboard doesn't light up like its meant to. The power supply was slightly damaged when it arrived, that is why I think it is that!
Here are some pics: http://imgur.com/a/ozkve
Here is the system specs: http://uk.pcpartpicker.com/p/3D4UL
Not really sure what else I can say.
Thanks
My system: CPU: i5-4670k CPU-Cooler: be quiet Dark Rock Pro 3 Mobo: Gigabyte GA-Z87X-UD4H Ram: 8GB Kingston HyperX fury (red) SSD: Samasing 840 EVO 120GB HDD: Seagate Barracuda 2TB GPU: Gigabyte GeForce GTX 780 3GB Windforce Case: Fractal Define R4 windowed PSU: Corsair CX 600W Semi-Modular OS: Windows 7 Home Premium.
Laptop: Dell Laptop - Some crap i5 and 8GB of DDR3 ram. OS: Duel Boot - Windows 8 & Ubuntu!
https://linustechtips.com/topic/150661-external-build-not-starting/
Fixed It
