Hi!!!
I have been looking for a DP(f) to HMDI(m). For a few years now i am coming across situations where i cant use display's or any other device because of ports. I want to create a kit that allows me to connect to any device no matter the port. The problem i have is that i can't seem to find any good adapters for DP(f) to HMDI(m). Can anyone recommend some? it would really help!
Thank in advance! have a nice day :)
https://linustechtips.com/topic/1506374-need-help-finding-dp-to-hdmi/
17 minutes ago, ytty said:
Hi!!!
Thank in advance! have a nice day 🙂
this may work im not to shure VMOJO DisplayPort Male to HDMI Female Adapter | DP to HDMI Coupler Converter | Full HD 1080p Compatible with Computer/Labtop/PC/Monitor/HDTV - Black: Amazon.co.uk: Computers & Accessories
Hi buddy, you're in for a bit of misery I'm afraid.
DP to HDMI and visa versa isn't straightforward especially if you use some of the more modern features like VRR (G / Freesync) or HDR or even worse a combo of both.
I've even had issues with DP > HDMI cables transmitting video but garbled audio.
Personally, I think its a bit of shame the GPUs only have a single HDMI port and the rest DP.
My solution was to whack in a GT1030 to spare PCI slot that gained me an additional HDMI port but for some that's not really a solution.
Can you elaborate on what you want to connect? PC / AVR / TV / Monitor / Console........ Also, what features are you wanting i.e. HDR, VRR, ALLM......
As I'm a bit of a home cinema enthusiast, I've got a fair amount of experience with multiple devices, cables and connections and not too janky!
C
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 5070ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 3080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Office PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Spare - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 980ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Annex - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 1080ti - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
I do have a mini DP to HDMI 2.0 adapter that seemed to work fine (I had a 2 slot card that used mini DP but also have an adapter to plug it into full size), but HDMI 2.1 is needed for the stuff you listed so yeah, more of a pain.
I think there should be a minimum of 2x HDMI personally, if nothing else in case one of the ports breaks.  Also HDMI is useful as optical HDMI cables are much more common and cheap, optical DP are rare and expensive, as I wanted one as the thick cable I'm using causes a black screen when I move my monitor from the stress on the port.
C
Hi! Thanks for your response.
Sorry for my late response. I want it because I want to be able to connect all kinds of displays, so monitors, TV's or beamers, to my phone or laptop.
I was beginning to think that it's going to be hard. I don't know if it's lucky or not but I don't want to use it for my top tier stuff, it's for when I want to work with a extra monitor ans there is one, or I want to watch something on a bigger screen. So u want to be able to use it but have decent quality that isn't too distracting.
I hope I elaborated enough!
Have a fantastic day :)!
Hi, that kinda sucks :/. I I'll have to look into it. Can you still give me the adapter you use?
Have a great day! :))
On 5/11/2023 at 12:45 PM, GOATWD said:
Hii!! Thanks for your suggestion!
Have a nice day! :)
I don't know where it is, but I am seeing a few DisplayPort to HDMI 2.1 adapters on Amazon, could you try one of those?
