So my MSI RTX GAMING X 3090 Ti just completely went unresponsive out of nowhere 3 months ago while gaming (Hogwarts Legacy to be specific), been using motherboard graphics U770 since then (no gaming) and I haven't been able to fix it. I sent it to manufacturer for further analysis I just got it today from them saying the card is alright and that nothing is wrong with it. I've tried to replace cables, monitors - nothing helped. I got some older Radeon Sapphire card from a friend today just to see if it's a graphics card problem or motherboard problem. Interesting thing is that both cards didn't work in first PCIe slot, but Radeon worked on second/lower PCIe slot, while my RTX 3090Ti did not.
The RTX 3090Ti is not recognized in device manager, just my intel onboard graphics shows up.
Has anyone had the same problem and come to a solution for it with anything? When I connect it, the light turns on but the fans don't spin. Under Device Manager, it doesn't show at all under the Display Adapters and I can't download its drivers unless it has that signal detected. Any suggestions?
Specs:
Asus Rog Strix Z-690-e Gaming Wifi
Intel i9-12900k
G.Skill DDR5 5200Mhz 64GB
MSI RTX GAMING X TRIO 3090Ti
Seasonic 1000W Gold Fully Modular PSU
Thank you for any answer/solution provided.
https://linustechtips.com/topic/1506244-graphics-card-issue/
1 minute ago, SIMONIMO3 said:
maybe the first PCIe slot shorted/broke and broke the PCIe connector on the GPU
hmm, but I sent it to manufacturer for further analysis and just got it today from them saying the card is alright and that nothing is wrong with it. The card worked for them perfectly.
https://linustechtips.com/topic/1506244-graphics-card-issue/#findComment-15934339
if you leave near a microcenter they might be able to troubleshoot it
you dont need an aio for anything but i9 cpus or heavy oc jobs just get an nh-d15 or peerless assassin
MARK THE SOLUTION AS SOLUTION
i am 14 so i may be wrong sometimes
@Bob__ is a w
https://linustechtips.com/topic/1506244-graphics-card-issue/#findComment-15934361
After thorough diagnostic it seems the problem was all along in the power adapter of the graphics card. This is not yet 100% confirmed, as I need to test it with another power adapter of that kind. Now it's weekend so I have to wait 'till Monday to test this and confirm. I'm just shocked that my graphics card went through 3 sets of repair centers and none of them had the idea to test original power adapter that came with the card. They all tested the card with their own power adapter so of course the card worked for them. The card is still under warranty so if it comes to that, I can request a new power adapter.
I just have a question for people on this forum - 'cause I have Seasonic PSU, I saw they have their own power adapter to buy "Seasonic 12VHPWR Cable". Link:  https://seasonic.com/12vhpwr-cable
Will this be a better option or the same? I just wanna know so I don't throw money away, 'cause I can get new original adapter for free, since it's under warranty, but I don't want to risk another failure with the original.
Thanks
https://linustechtips.com/topic/1506244-graphics-card-issue/#findComment-15938553
